Dse8610 módulo de controle automatico
zbeng
NUEVO A ESTRENAR SE VENDE EN MOSTOLES /MADRID
CONTACO : 610962285 / mullerritter@gmail.com
PRECIO : 1100 negociables
DEEPSEA Auto Start Load Share Control Module DSE8610
Introduction:
The DSE8610 is an easy to use multi-generator loadshare system, designed to synchronise up to 32 generators including electronic and non-electronic engines.
The DSE8610 monitors the generator and indicates operational status and fault conditions, automatically starting or stopping the engine on load demand or fault condition. System alarms are annunciated on the LCD screen (multiple language options available), illuminated LED and audible sounder.
The event log will record 250 events to facilitate easy maintenance. An extensive number of fixed and flexible monitoring, metering and protection features are included as well as comprehensive communication and system expansion options.
Using the DSE PC Configuration Suite Software allows easy alteration of the operational sequences, timers and alarms. With all communication ports capable of being active at the same time, the DSE8610 is ideal for a wide variety of demanding load share applications.
Key Load Share Specification:
1.Peak lopping
2.Sequential set start
3.Manual voltage/frequency adjustment
4.R.O.C.O.F. and vector shift
5.Generator load demand
6.Automatic hours run balancing
7.Mains (Utility) de-coupling
8.Mains (Utility) de-coupling test mode
9.Dead bus sensing
10.Bus failure detection
11.Direct governor and AVR control
12.Volts and frequency matching
13.kW and kV Ar load sharing
Key Specification:
*Comprehensive loadshare capabilities
*Configurable inputs (11)
*Configurable outputs (8)
*Voltage measurement
*Built-in governor and AVR control
*kW overload alarms
*Comprehensive electrical protection
*Magnetic pick-up
*Electronic engine capability
*RS232 & RS485 remote communications
*Modbus RTU
*PLC Functionality
*Multi event exercise timer
*Back-lit LCD 4-line text display
*Multiple display languages
*Automatic start/Manual start
*Audible alarm
*Fixed and flexible LED indicators
*Event log (250)
*Engine protection
*Fault condition notification to a designated PC
*Front panel mounting
*Protected front panel programming
*PC configuration
*Configurable alarms and timers
*Configurable start and stop timers
*SMS alert messaging
*Remote monitoring
*Compatible with DSE8700 Series
Key Benefits:
1.RS232 & RS485 can be used at the same time
2.DSENet connection for system expansion
3.PLC functionality
4.Auto voltage sensing
5.Five step dummy load support
6.Five step load shedding support
7.High number of inputs and outputs
8.Worldwide language support
9.Configuration Suite PC software
10.Direct USB connection to PC
11.Ethernet monitoring
12.USB host
13.Data logging & trending.
